dmw56
Got the front end finished tonight. I just wanted to point out a few things to the new guys building their rods.
When you put the spindle on the axle the thrust bearing goes on the bottom with the dust cover facing up. Make sure you check the clearance between the axle and spindle and add shims if necessary. When you put the kingpin in make sure the notch is facing towards the inside for the locking pin to go through. I also made sure to use Locktite on all the nuts and bolts. I don't like the idea of something falling off the front end.
When installing the disk brakes I had to grind out a notch in the spindle backing plate for the caliper to fit correctly.
You can see in this picture how the steering arm tie rod hole is to the left of the kingpin centerline or farther out on each side. This is to keep the Ackerman angle correct with a front steer setup. These are steering arms from Total Performance.
Since I'm using 5 spoke offset wheels I painted the brake disks just to look nice. I used high temp paint on these.
