Life can be a beach sometimes when you least expect it.
Hope you heal up quickly so you can get back to what you
want to be doing.
Thanks POPS and also thanks to evryone for the good thoughts.
And speaking of doing what I want to.........
I did manage to roll out to the shop and get a coat of epoxy over the primer on the doors. Scuffed, then wiped down with wax and grease remover.
Now they are set for the winter.[cl
As per the seperate post I started You can see in the pics how dry the sealer went on the first time. It was mixed and shot with out reducer per Manufacturer's directions. Their directions stated that for sealer use no reducer. For primer use reducer. Turns out that it is a sealer regardless and it says that either/or BS on the can to comply with VOC laws.
Too bad I couldn't get a pic of the me holding the door balanced on my lap with one hand while rolling the chair with the other.
Interesting doing all this from a sitting position.[S
Hopefully the next step will be to get some help over here and hang the doors back on the cab.
Thanks for looking in......
Torchie.
