DJ3100
quarter panels
I did a lot of on line research and found a method of welding in panels that is supposed to be easier. You make the cuts without leaving a gap and fuse TIG weld without using any rod.
So I scribed the line, used a cut-off wheel leaving about 1/16" and used a flap wheel to grind exactly to the line. But holding the panel in place proved to be a challenge.
At any rate here's the first panel.
[/URL][/IMG]
Notice the studs above the weld? That was a T shaped dent that I found after I welded in the panel. Should have felt around inside before welding. There is well over 40 hours in trying to fix that dent. There is a brace behind it so no hammer access.
[/URL][/IMG]
[/URL][/IMG]
Here's the rear panel. The rear's were a lot easier because they had more contour.
[/URL][/IMG]
[/URL][/IMG]
I started these in June and "finished" them last week. They are not as good as I would like them to be and I can't even say I'm sure they'll work - but I think they will. But I'm moving forward.
