Master Brake and Clutch
I got a Speedway 8" dual diaphragm booster and Corvette master cylinder. I had a 3/4" Willwood cylinder for the clutch master left over from the F2stang..
I tried out the Ford original master cylinder location, but it was a little close to the engine, but finally figured out that if I moved it 1" to the outside I'd be able to use the original pedal set up.
(This post sort of goes backwards -starts at the end. Hope it doesn't confuse everyone.)
[/URL][/IMG]
[/URL][/IMG]
The original has a stepped bolt going through clutch pivot and then the brake. The Clutch has two 3/4 ID x 1/2" long Thorsson needle bearings. Never seen that before. Grainger had the exact same bearings.The pivot bolt is hardened and shows no wear.
I added a threaded boss to the brake pedal and a longer one to the clutch pedal. Also, in you can see the finished filler plate/lower column mount.
[/URL][/IMG]
I thought it might be possible for the extensions to cause the bracket to bend, so I welded a gusset plate to the head of the pivot bolt, and some threaded bosses to the bracket. I don't have all the bolts in place in these photos. The hydraulic press and a torch was used to hot shape the clutch and brake pedal so they would clear the column and someone's size 12 clod hoppers.
[/URL][/IMG]
I had to mod the bracket with a few cuts.
[/URL][/IMG]
I cut a little at a time this is about 1/2 of the total cut.
The raised portions of the firewall allow my 1/4" plate to fit flush on the inside and still be the same height on the outside. I tried to match the factory radii on the finished plate. Can't really see it from anywhere.
[/URL][/IMG]
