DJ3100
Here's my new clutch fitting set-up with a bleed screw at the very top.
So far there is no pedal, it moves with no resistance. The internal hydraulic Throw Out Bearing does not even twitch.
I have:
1. Pushed fluid with my reverse bleeder into the upper and lower bleed screws.
2. Pulled a vacuum on the upper bleed screw - trying to pull any air out of the TOB. Did this both with the pedal depressed and not depressed.
3. Pedal bleed - open bleed screw - pedal down; close BS - pedal up. Maybe 50 times. Plenty of fluid moves out of the BS and no air.
4. Done #3 from the bottom BS.
5. Depressed the pedal to close the MC port and pushed fluid into both BS's.
6. Pulled a vacuum on the master through the reservoir.
7. Checked for leaks including checking the TOB. Haven't found any.
There has to be a lot of air left in the system or there is a high (or medium) pressure internal by-pass (leak) in the master.
Ideas?
I have:
Ideas?
