Huryinhoosier
Active member
A couple of years back, a close family member died and left behind this car. starting out life as a 70 Impala,Its been in the family for years and although some think its not much to look at, its a family treasure cause it was handmade and its been around as long as i can remember.
The current engine is a 327 with a factory steel crank. Its .030 over and needs one piston replaced. Im thinking about going ahead and putting a 350 or a 355 to replace it and trying to trade my way into it. When completed, the car will go back to my sister so her and the kids can enjoy it once again.
Any ideas what the engine might go for. It was running when pulled.90 pounds of compression on number 6 due to stuck rings due to the piston. Cylinder looks fine as well.
Engine casting is 3782870
Crank casting is 4577
