Bamamav
That Merc coupe with the grill off of the 4 door will be sharp!
Enough rambling around let's get some progress reports, eh. Oh, ya, that's me. I finally got the speedometer ratio adapter that I E-bayed. I was a little let down because it was a straight through one and I thought I had ordered an offset one. Its was almost what I wanted and it screwed right on the transmission speedo drive and the selected adapter drive pin fit also. Then it became obvious, even to a flaming optimist like me that the speedometer cable would not bend around the brake power booster and screw into the adapter anymore. Tears filled my eyes there for a time while I tried to see what could be moved two inches sideways, the booster, no; or the motor and transmission, nope. I took the adapter over to my little pile of warn out adapter parts and started taking an old Kenworth one apart because it was an off-set case, so would maybe hold the new gears. Then I took the new adapter apart and was checking out the gears when it struck me that I could maybe just put the new case back together kitty-wompus and voila I made it into an off-set new adapter. As I crawled back under the truck I happened to find a piece of paper that on closer inspection, told me how to do that. Men, Huh. Never read the instruction first. Anyhow, it got screwed on there and moved around a bit, so it fits like factory.
While I was fiddling there I noticed that the drivers side running board was warped in near its front end so I pried it out as I heated it and left it blocked to cool. About then supper was calling me.
It seems like I've turned my back on the old girl [the '36] and some of you may be right. Tonight, I topped up the antifreeze, primed the carb and took off for a test drive. The transmission and shifter feel good. The speedometer speed reading was guessed at with flaming optimism and I over shot my goal of having it show the right speed. It reads about 10/7 too high, but I can get different plastic driven gears for the end of the cable.
Thursday night at the A&W is a large possibility.
