Dr Crankenstein
Buckshot is a welder, a machinist, a racer, and a builder of things.
Does he happen to be one of the Rutherfords?
Yes Doc, Buckshot is Steve Rutherford, the head dude. He has a brother that races a bit and a son James that races too.
That's not the kind of update that we want, Mac.
Sending healing vibes your way.
Doc, I think the new pressure plate will fix two things; the mismatched finger height causing chattering and the worn out pivot pins making a jingling sound unless I was riding the pedal.
I am paranoid with driveline angles now so I'm checking things out in this picture. There is supposed to be a red laser dot at the one inch mark on the tape measure, right at the bottom, but it doesn't show up. If you're worried about the transmission 'plum string' being a half an inch off plum, well, the front of the motor one is a half inch off plum too. Anyhow, I think I have the two laser beams, [the one going forward and the one going backwards], parallel.
