47 Dodge Rat… Budget Build
Ta2Don
Jun 26, 2014
46
Searcy, AR
I picked this up from a friend a few months back and finally dragged it home to begin the build. ;)
The 47 Dodge WD15 body and bed are mounted on a S10 frame… Plans are to drop in a Carbureted '99 Chevy 305 with a thumper cam backed with a Turbo 400 trans. As can be seen from the pics, the floor is gone and the P.O. had rigged some motor mounts that would not work for me. A proper set of V8 swap motor mounts from Trans-Dapt via Jegs are due to arrive tomorrow.
I'm in the midst of re-working a '65 Short stepper Chevy, and this Rat is a side project that I just had the need to do… I plan on this being a rather quick build as compared to the 65 that is pushing 2 years thanks to a bent frame issue...:eek:
Enjoy the pics and feel free to comment...[cl
    124.1 KB
    126.4 KB
more pics
Front Clip off and funky Motor Mounts
    204.9 KB
    142.5 KB
    128.7 KB
More...
Floor is gone and some other shots...
    110.6 KB
    153.9 KB
    164.3 KB
…and more...
The funky flat steel motor mount on the pass side cut off, the D/S unbolted…
The Pedal car body on the wagon was thrown in the deal…:D
The bullet holes in the back of the cab are staying...:cool:
    168.2 KB
    101.8 KB
    86.9 KB
Looking at those pics, I don't think I would trust any of the previous owners "work". I would seriously look at anything he touched.
Good luck with the build. I'm building a Dodge too.
Thanx
Thanx Guyz!!!:D
P.O. Welded the cab to the frame and bolted the bed on…[S
Gonna cut the cab loose and fab some bolt-on mounts...[;)
Plans for the upcoming weekend is to get the motor and trans mocked up in frame in order to mock-up steering setup and Brake pedal and booster mount…:) …as well as look at how to wet-up the floor frame...:confused:
got a cool look to it, good luck fixing the previous owners work
I can see it's potential. Have fun and good luck .
I'm in the process of doing a resto mod on one right now.
I really love this body style.
Thanks for looking in Guyz!!! :D
The Motor Mounts showed today...:cool:
Having done the S-10 frame swap and owning a V-8 S-10, I don't think those mounts will work for you if you plan to put them in the "stock" location. For the S-10 V8 you need to move the engine forward and I think you'll need to move yours back. I'm interested to see how they work for you though.
This is going to be a cool truck!
My brother had a '39 Dodge on an S-10 frame.
