if you use modern eurothane window sealant it wont matter how wide the flange is. even if you only have a 1/4" on one side of the gless it isn't going anywhere. just have it clean and use the catalyst primer when you do it. My only concern is if there is any cowl shake / twist is it going to crack the glass. those windshield were rubber set and had some give. Looks good though.
