I'm back on the steering column. jfg455 got me thinking about what I really want and don't want. I really don't like the plastic column, the steering lock, the key in the colunm and the little lever you have to push to redeem your key. I do like self cancelling turn signals, but I can live without them.
I also decided I don't need/want tilt (they just don't look right roadsters), I just need to be able to adjust the column angle once the seat is in.
So, after I got the cab mounted, the hole in the floor, and got the brake pedal doing what it is supposed to do, I spent the rest of the morning tearing apart the column I got from Truckster. I think I can use the shaft and make a clean housing. The upper bearing ID is .750; the lower 1.00", so it will be easy to find some cheap bearings or bushings. The splines look the same as the '48 steering wheel. Photos this afternoon.
