gold03
He lives in an "Altered State"!
Hey DR. Do you name your rides? If yes, are you ready to tell?
Gold03
Gold03
Gold03
I really want to hear this thing run!!!! Get it into gear. So, I have to ask, You going to put some quick connects on the back and tow a BBQ grill to shows? You could probably make a killing selling burgers.
Going to carry some burnz-o-matic torch tanks for reserve fuel?
Just had to poke fun at the propane a little. Mainly because I am jealous I didn't find something that cool to do. [cl
I actually planned on adding a slide out BBQ grille, already talked to the roush tech about venting vapor to run a grille, and a propane powered cooler/fridge...
We all do unique and different things, including your dodge man, I really like your truck!
Small update, Grille shell should be here this week or next via Greyhound,
Scored a set of factory service manuals for the 2010 E-250, mainly for all the wiring diagrams, but never know, might come in handy if I need to troubleshoot something, much of it is the CAN system, if you are familiar with that setup you know what I mean. Also this motor is drive by wire, electronically controlled throttle plate, so I want to make sure all the overrides are in place for safety..
You find the Dodge grill you were looking for?
This sounds like it is going to be a nightmare to set up, good luck. I assume by CAN system you mean CANbus. I have some experience with it. We have a few systems at work that run that. Not to bad to work with. All the same, good luck.
Shouldnt be too bad, the hard part is the main harness, stripping that down, and shortening it or lengthening it where needed... I have the Factory Service manual & wiring diagrams... should not be too bad.
