I was thinking a slide out, but too much other crap to finish up before I get on to the fun stuff...
I'm hoping I can build one area in the trunk as a fridge area, and then on the other side have a slide out grille form under the bumper.
Not much gas in the tank tonight, made 2 pieces for the floor, did some final measuring for the heavy brackets to mount the tank to the frame, going to finish up the sketches tomorrow for the pieces I need to cut to weld to the frame.
I also picked up a couple bushings to go with the thompson shaft I have laying around, going to use it for the brake pedal pivot once I make the block to house the bushings...
