gold03
He lives in an "Altered State"!
Things are looking good Dr. You are making good progress. [cl
Great job on the hub caps DR.
Did you fab up that filler ring or was it for something else you repurposed?
Torchie.
I like the hubcap mod you came up with. I'll put that away in the memory bank for future use.
Shows another way to skin a a a a, Oh well, cat [ddd
Who done your lazer work?
Lucky dog you [drOur shop has all the equipment, prototype and production tool shop! [cl
Well, mostly reverse progress lately, but moving in a direction is good I guess.
I didn't like the way I had the column, I noticed the hole where I want the steering shaft to come out was not centered with the column, which made the column sit on an angle. Last night I cut out the dash area (also to remove the spots for the stock pontiac gauges) and I moved it over a couple inches to the left, now its centered with both the seat base (pretty close) and also the hole in the firewall.
Question is, will I be ok with the steering wheel being only a few inches awas from the door... I guess I'll post it up in the Q/A section so I can see how close you guys run the wheel to the driver's door...? The setup I am looking at right now puts me about 10" from the door to the center of the column, which I think is about 3" further over than stock if my memory is serving me today...
