05snopro440
Thanks for all the input guys, I'm going to throw the seat in again and sit in it to make sure everything feels right and that the chest to wheel distance is similar to what my car has as well... It just really looked weird moving it over that far, because of the cab being so tapered from back to front...
The plan is a 13" wheel, with a cardboard assisted template it didnt look too small, and gives me some knee room as well.
I'm thinking under launch, the motor should rock away from the steering shaft, so I can probably move it back a little to the center of the cab which puts the steering shaft closer to the head... hmmm
I'll try to snap some pics too.
My cab is narrower than yours, but I moved my wheel out towards the door a lot from where it was originally. With mine, the original position sat you almost in the middle of the cab. My column location now with a modern bench seat sits me exactly where I want to in the seat, and in relation to the rest of the truck. Just because the column was in one place when new doesn't mean you want it there now, 60 years later. You might find that being closer to the door is what you want, so your plan to put the seat in and check is smart.
The motor will torque "up" on the driver's side, but I'm not sure how this makes a difference to your steering shaft placement? Maybe a pic would help...
