05snopro440
The things we learn the hard way, lol. I ended up taking the heater plenum under the dash completely apart to sort out how it worked, so now I have heat and defrost, sort of. With the blower just behind the grille and the heater core just behind the radiator core support it's got a long way to go before heat hits the passengers. I do plan to take apart, clean out and reseal the under hood sections, who knows what's inside there.
I added seat belts last weekend. That was labor intensive, but not hard. I ended up taking the back seat out completely, which was a real wrasslin' match. the rear side window trim and the rear interior side panels. Took about 5 hours to do the job, most of it figuring out what needed to come out and where to put the mounts.
How did you do the upper mounts? I've seen kits from places like Juliano's where you tack weld a plate in.
