Update time.
Spent some time cleaning things up in prep for reassembly. Pulled the tie rod assemblies out so I could clean up the sleeves and install the new tie rod ends I bought. Turns out my plan for less expensive tie rod ends hit a snag. The threaded ends are fine, the location of the zerk fittings would have worked. However, the diameter of the tapered studs was too small and my window for returning them passed, two days ago, lol. Teach me to slack off. So I have new tie rod ends coming. Decided to pull the pitman arm off so I could crape off decades of grease and clean it up, only to decide that I may as well replace the pitman shaft seal. Would have been nice if I remembered that before I finished my tie rod order, oh well NAPA can get it for me for about the same cost
Cut one coil off the Aerostar springs I installed earlier this year. Got them back in where they belong. Bought a Pneumatic cut off tool, but it appears either my compressor can't keep up or the tool is under powered, so I converted an old miter saw into a chop saw and got it done.
Found that my oil pan screws were all loose, I suggest this might be a maintenance item added to the oil change check list. Heck this might even slow up the oil leak I have.
Tomorrow, I hope, I start final assembly on the disc brake swap. I should have all the stuff I need on hand, except the tie rods. Might reinstall the old ones just so I can move the car about.
