jmlcolorado
Here is a close up of the urethane. I glued the glass in place on the pinch weld then let it set up for a few days. Then taped off the area around the windshield, filled it in with more urethane and tooled it off. Used soapy water and smoothed it the best I could. Urethane is a mess to work with, so be prepared with a couple rolls of paper towels and some mineral spirits to clean up everything you get it on that you don't want it to stay on...
Also glued the rear Plexiglass windows in and put my visor back on as well. Even hot wired the thing today, ran the cam in and am pretty pleased with how the motor sounds. As in it sounds LOUD! Tried to post a video, but it won' up load. File is too large maybe...?
Dang! The urethane actually looks pretty dang good!
If I fight more then 2 pieces of glass into the factory style rubber, I might just go this route.
You won't have to have the cuts exactly perfect with this method too, which is a plus.
