CSCStreetRods
- Joined
- Nov 6, 2008
- Messages
- 51
few more pics of the headlight bracket. made a few modifications and drilled hole for headlight (not the one i will use but gives you an idea.
the front part is welded and ground down a little will do the finish grinding and shaping later. need to weld the back part when i finally get the motor out and frame on its side.
