8literbeater
Bama, the axle is bolted to the cradle sort of like ladder bars. It won't wrap.
Only thing I see, and I may be over thinking this, is if you get any spring wrap, it will force the cradle forward, putting strain on the shackles on the single spring, and possibly binding the cradle against the frame. Does that make sense?
Digging the stretched Bug! Looks a lot like a Fiat Topolino!
I understand that at the rear.....the front of the cradle is what I was referring to.
With the axle bolted to the cradle and the support bars eliminate wrap or flex and the leaf spring running flat shouldn't be much forward and back motion
I Wasn't trying to rain on your parade Ben, I was just wondering about the mounting. Sounds as though you have it figured out. The snubber on the cross spring sounds like a good idea.
Guess I'm slow but don't understand the reason for the cradle inside the frame. Got a short explanation? [S
Rattler
Here's some pics of Mcmullens A100. You may be able to make out the straight rod front mount he used in the magazine pic - I have to think it wouldn't have worked too well, forcing the whole engine cradle to twist when cornering... sorry for the tiny pics....
Love the build. You do great work. That being said, when do I get to see the completion of the V8 Beetle Street Rod?[P
