Bamamav
Finally got a little warm weather last week end and this one too, so I got a little time in the old girl. Got the trans mount roughed out last weekend, sorry no pics yet. This weekend, I started on the engine mount cross member. Haven't decided yet if I'm going to try and drill the frame and cross bolt it in, or just weld it on. I'm thinking a single grade 8 3/8" bolt should be enough to hold the weight of the engine, might put two just for insurance.
Anyway, the angle plate goes on the outside of the frame, just in front of the steering box, the box tube runs between the oil filter and pittman arm. It will then have a piece of the same tube on the bottom side that will go under the oil pan, the engine mounts will be on this piece. Right side should mirror the left. Here is the rough tacked left side.
I will box the spacer in when I finish it. I meant for it to be on there with the open end against the flats, but somehow turned it wrong when I tacked it. Oh well, just a bit more cutting and welding.
