smallfoot
Looks like everything is fitting nicely!
Holy cow that's a tight space to fit all those parts in[![]()
Wow. That is crazy... I had to go back and look at the pictures to believe it.You got that right! And there's still more to go in, AC condenser, exhaust manifolds, power steering lines, etc. The bay is long, but narrow. It will be quite full when everything gets put in place. I could set the radiator back toward the engine some, but then you get into fan clearance problems with the hoses. What really makes it tough is that the front end is one welded piece except for the fenders and grill.
Would you trust this fan? Or replace the plastic blades? I reversed it for more hose clearance, may turn it back around after I get the water neck and hose installed.
As I am not familiar with the installation, I can only guess at the wrench you made. Please give is a picture of it, if you don't mind.I'm sorry, Bam, but you're wrong.
Think like a boat propeller. It can only provide forward thrust in the correct rotation and orientation. If you flip the prop 180° and spin it the same rotation, it will provide reverse thrust.
I also hate those threaded fans! After the last couple (cursing and swearing) swaps, I quit fighting with a pipe wrench and made myself a long flat wrench. Easy now!
