Managed to get a little done today between thunderstorms.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Even though I'm working under a roof on a concrete floor, when it starts lightning close by, I get inside!
Got the pittman arm off the replacement steering box, then took the S10 box off the car. Discovered the shaft was a little more misaligned than I thought, so I'm going to change to a U joint and DD shaft instead of the factory GM shaft and rag joint. The replacement Firebird box is 2.75 turns, lock to lock, so I'm thinking it might steer faster, don't know. The S10 box was fine until you put fluid in it with the pump, then it got a sticking spot at dead center. So hard in fact, it took a bit of effort to get it off center, causing it to jerk. Knew that wouldn't work on the road, so it's getting replaced. Never had one do that, it steered manually just fine, no tight spot. [S
Next, I'm putting the FBird box on, then putting some bracing on the motor mounts, just not quite happy with them yet. They would probably be fine, but I'd rather be a little overbuilt and have no worries.
Nothing picture worthy, yet.
