I love long weekends! Had yesterday free to do what I wanted instead of having to cut grass and everything else. Set out yesterday morning with a goal in mind----get the motor in the car! First was the rear seal, slicked it up and it went into place straight with finger pressure-- that's what I'm talking about! Took my wood board with the hole cut in it and tapped it into place with the hammer, easy peasy! Then, I cut the heads off a couple of bolts to use as guide pins, lined the motor and trans up, slid together like there was a magnet pulling them together. This is how stuff is supposed to work, LOL! After installing a few items on the unit, trans cooler fittings, dipstick, oil pressure fittings, etc, it was time for the big show. Slowly, carefully, jack the cherry picker up until I had it high enough to clear the body, then slowly walked it forward with the help of a tire bar. Everything went smoothly, dropped it in on the mounts and assembled them. Got one side loosely fastened, then wiggled it around and fastened the other side. Woo Hoo! Felt good to see it sitting in there again. Started hooking up things on the bottom side, starter, one side of the exhaust. Took a break for lunch, which was the wrong thing to do...After I ate, I just didn't feel like crawling around on the floor anymore, so I just did a few top things. With my energy level dropping, I polished up my new valve covers to install, then couldn't find the new gaskets I had bought. Had to sit them on anyway, as well as the new air cleaner. A little preview pic of what's coming. Probably won't get back on it until next weekend, but the end is in sight now.
