DozerII
Wow That's awesome.
torchie I have so much stuff right now, but when it comes up cheap I have to buy!
my first 52 showed up, not bad shape.
the cab is pretty nice with just some rust in the kicks, I will probably use it on the next project because it needs the least amount of work. the front end though, will probably end up like bickle's 2 ton front end did recently
braced and ready to hang on someones wall. fun little side project, if it sells I will cut the 52 front off and dooitagennn
stopped by bowtie bits for my semiannual spend. he had the patch piece for the dent in the cab too.
finished the parts on the paying job and the garage was kind of a pig sty, so I put in some work. that cnc table fits so nice in the corner, out of the way (not visible here)
washed out the cab, it was full of mud and sticks. when it dries out a bit I will vacuum the little bit that is left.
aside from a couple small things like headlights and valve cover gaskets, the only big spend items left are the seat and the gauges. I like the dakota digital 47-53 setup because of the OBDII interface, but I DONT like that its a 4.5" gauge with a 1/2" adapter ring. why not just make a 5" gauge? looking around, DD makes a gauge set for dual 5" holes, I may try them out instead, same OBDII interface, same myriad of color choices, same PRNDL, etc.
the only thing that can slow me down right now is that dent patch, the body mounts are 100%, no rust repair bed or cab, no missing parts. should go fast from here.
