smallfoot
What tranny and motor did you get in the s10?
The kits are for putting a V8 in an S10. Odds are against needing to move the engine in that direction. On my 39, I centered the front fenders, and added the cab, more or less. Then you can sort out where you need to stick the engine. You should have more working room than the S10 engine bay has. I used stock motor mounts with slight modifications. Knowing what I know now, I might have done it a bit differently.A balmy 18 degrees and snow here today and this just showed up in my front yard.
99 S-10. 2 Wheel drive long wheel base. 122.9 inches
The Dodge's Wheel base is 123.5 Inches. So I think I can get it where it needs to be without having to cut the frame.[cl
I"m done flip flopping on the frame for this project. This will be it(Unless a beautiful stock 49-50 Dodge coronet frame falls from the sky.).
So all you S-10 guys out there clue me in on doing a V-8 swap.
I suspect it will be a SBC as at this point I need to go with what works best.
Are you using the kits that are available or what??? HELP.![]()
If you got a 4.3 motor the tranny could probably work unless it was something you just didn't want. 4.3 same as sbc bolt pattern.
The rear axle can be adjusted with an adapter plate, with a pin on it, that hooks over the stock spring pin, and relocates the axle. These are available for centering the axle on an S10. I am sure you can make one to your specs. You will most likely be softening up the rear springs anyway.
You are lucky to have a pattern for setting up the body mounts on the new frame.
You should be able to get some serious rubber under it now. You may need to tub the rear. Stock S10 rear is good up to around 400HP.
So after spending the morning researching I'm considering just using this V6 in the Dodge. If I get it running.
Joedoh you are one of the reasons this site is the best anywhere. ����������
All that info made my head hurt!
Joedoh is for sure the King of S10 knowledge![cl[cl[cl
Reminds me of why I hate electronics so much and always get rid of it. I'm old school, I understand old stuff much better.
Joedoh you are one of the reasons this site is the best anywhere.![]()
