tmgant
I'm a ford guy, but I would ROCK the finishd chevy truck. Tobby
Wouldn't there have been a hole in the axle where the through bolt for the leaf spring orinaly was? there should a be a pin in there.
What is the axle out of? Is that an old Econoline?
I'm not sure what indexes the radius arm onto the axle. I like the look of it, but might have added a plate to the mounting surface with a matching bolt pattern.
I believe you're right ZZ. I have one out of a 60s Chevy van that I thought that one looked like...That's a Chevy axle, see the little triangle shaped boss on the topside of the drop section.
[S However, one would assume the center of gravity has been altered a bit.![]()
I would say so... Even with the Corvette suspension it probably handles like a phone booth, since it is one...
But I would still drive the crap out of it.... and I am sure you would too.
