I did a little bit of shop time today.
I need to build a "Step" for lack of a better term.
Pics. 1-2 The area that need filled in.
Pics 3-7. The materials at hand.
Pics 8 -9. The step as it is in the front door opening.
MY plan is this. I will use some home builder terms to try to keep things straight.
[cl
The 1x1 square tubing will go up under the sill. Right at the outside edge of the remaining sill.
This will reinforce the sill as well as giving me the "Toe kick" that I need. (There is those home builder terms.)
To the outside of the 1x1 stock i will attach the smaller square stock.
That will give me the tread that I need for the rocker skin.
I will weld in the 1x1 and tie it to the new dog leg.
Then at the B pillar, I will do the same.
This will make the sill good. and strong. I can also bolt down through the sill and the 1x1 Once the sill plate trim is back on nothing would be seen.
That's the plan for now. I hope to get started back on it tomorrow.
Things are going good here. My right hand now looks like my left one ,again.
Keep on keeping on......
Torchie.
