gene49
Like the gussets.
You going to have access holes through the frame for those nuts?
The inner channel will stay open to allow access from top and bottom.Like the gussets.
You think the bracket will fail? Or the nut will be hard to get to?You have more experience then I have, but it looks like a bad dream to me down the road a few years.
Yeah, I never considered having to drive the bolts out.I'm thinking that 5-10 years down the road, if those boles ever need to come out, you (or someone else) is not going to be happy about not being able to put a socket on those nuts, or be able to drive the bolts out after one might have gotten the nuts off.
I try to build stuff so one day when someone has to fix it, I didn't create a problem for the person.
I don't see a problem with the brackets or with the gussets you are planning, it just not having access to put a socket on the nuts, or the ability to drive the bolts out once the nuts are removed.
