Awesome!
Bob
This is what true hot rod building is all about. Way back, I built a 1950 Fiat coupe. I used a 409 rescued from a B Altered Anglia which had graduated to a 427.
The body shape changed slightly in 1950 and I replaced the old steel front end with an narrowed Anglia one piece fiberglass that was left over from a local business who used to make them. No money to buy a 400 turbo, so I used a plenitiful and cheap chrysler torqueflite which I mated to the 409 with home made adaptors. As the chrysler trans was so long, I ended up with an 11" drive shaft! Amazing, the whole package worked. I had a push button set up in a raised aluminum cast tunnel console that was pretty neat. I ran it on the street as well, using old Mickey Thomson grooved slicks. Rear end was an early chev narrowed with cut and welded axles. This was another item rescued from an early funny car build.
Seeing your thread brought back many memories. My car was much more "back yard" than yours. I am truley impressed with what you have accomplished in a basic garage. Congratulations. You are an inspiration!
John
