Finally sealed the deal!
yea Bama thats what I meant other than the swivel if you can run the hoe it wouldnt take long you can run the track hoe .. the kamatsu and deere operated the same on our track hoes , but the back hoe, the arm movement was different seemed backwards after being on the case and kamatsu , but it didnt take long to get it figured out .
Somebody probably had the lines reversed. The wood yard I worked on had a big knuckleboom that the grapple lines were reversed to what our other machines were. You had to be careful when you first got on it if you had been running one of the others or you'd be dropping logs instead of picking them up!
It took a bunch of hrs to get used to skimming the bottom of the tank ,with our new back hoe Deere , but its all good now , We did look for a valve or something to swap the controls over when we first got it , but no luck . .. we have to clean a tank out 4 times a year or so , and you have to just touch the tank bottom and rake out the sludge, without damaging the liner . Same with the long-reach track-hoe, we dig out 3 holding ponds and you cant tare the liner ..
