custom cabby
okay... got my welder lined up finally and my next question is... GAS? what and how far will a tank do me for?
maybe I should clarify.... it's a lincoln 175
Excuse me, I thought it was a Lincoln but its not... I thought it was b/c I remember seeing Lincoln on the last empty roll of wire... Its a 110watt Century 100 model # 117-050 wire feed welder... Its got a heat and speed adjustment for the wire... I'm using flux-core wire...
I've been told by a couple body guys that I shouldn't be able to even use that welder... But I've shown pics to a couple of em of stuff I've done w/ it and they say my tachs look good... They said somethin bout the halos lookin good (I dunno what that means) and the penetration... I could post up some pics if ya'll would like so you could critique me...
Anywho, do you think I could weld HEAVY stuff w/o gas?
If you do frame or suspension welding you will want a 220 volt welder for better penetration whether you use mig or a stick welder.
That Century looks like it does an OK job with sheet metal. You might want to get a used Lincoln buzz box. Can usually be found on Craigs for ~$100.
I too use a Hobart Handler 135, 110 volt. It does a good job but be sure to bevel your connecting edges to a good 45 degrees and more than half way the thickness of the metal to get good penatration. I set my amperage on 4 , the highest setting, and set the wire feed on 40-50. I use 75/25 gas and run around 10-15 psi on the gage. 023 wire.
So far I have not had any trouble welding 3/16 tubing with this unit. Its also good for sheet metal, patch panels, at the proper settings.
Followering the chart inside the welder cover will get you close to what you actually need. Fine tune from there.
Good luck and happy building
