When you get good at it, you won't have to grind an arc weld. It will look as good as a mig weld. Grinding is a whole topic in itself. Beveling the two edges before you weld, not grinding too deep, grinding with the frame, not across it. Grinding (then sanding) with smaller and smaller grit, to get those grooves into surface scratches.
There is alot to it.
Saw a cracker box arc welder in the paper the other day for $100 bucks.
I bought my hobart 187 220volt mig from a tractor supply store....
thinking of a hobart 187 also. Welding skill aside, is this welder capable of doing frame work?
Sorry bonehead but what do you mean by a cracker box arc welder? is that a brand or slang for a type?
