pistolpete
Been having a debate about the front split wishbone mounts. Maybe putting too much thought into it, I could use the standard tab off the frame, but I will end up with my steering arm hitting the wishbone without modifying the steering arm (not a big deal). But then for thinking if I move the wishbone mount closer to the frame centreline I can avoid the steering arm issue and put in a little more triangulation to the wishbones. I realize mounting the wishbone inside the frame rail will be a fair bit more work then heating and bending the steering arm, but it will add a fair bit of strength to the frame as adding bracing to the centre crossmember. Give me your thoughts suggestions etc... just not sure how I want to proceed.
This is just a rough placement one on each side to give an idea what I am thinking...
