Hole in the head project
I installed a 6.2 LS out of a 2012 Camaro into my 65 GTO then lowered it. Ended up punching a hole in the pan so I raise it 2" and like mucho better.
Yeah, a sensible ride height makes sense, but I walk past sensible cars at car shows. I keep flip-flopping on what the ride height will be.
Maybe skid plate the bottom of the crossmember halo?
I was looking at pictures on my phone and figured out that I can't have as big of a hole in my crossmember. My lower a-arm mounts are where the tubing would be. I may just notch like this and box the hell out of it.
Trying to stay low buck. ...trying. I cut and then I cut some more trying to get it low enough. Now I'm trying to figure out how to add "some" strength back in. I'm trying to build a tubular k-member in the middle. I notched out the bottom to sink a piece of 1.5x3 across the back and then box in the sides and bottom. 1.5x1.5 in pics because that's easier to play with.
Sorry, but it doesn't give this guy a very warm fuzzy feeling, especially with the control arms attached to the nearly completely missing cross member.
I'll be watching how you brace this one. Is there an inch and a half clearance under the original crossmember that can be used to brace it?
Had an old dirt track car where they cut the complete center out of a crossmember under the motor, then added a bolt in plate on each side and built a bolt in tube shaped center that was 2" below the original center center section, and there was a bolt on tube brace above the motor. That chassis was over 20 years old when it came to me (was one of the best handing cars I ever had). We used it for 3 years, then sold to to someone else that used it a couple more years.
Basically, they welded a couple pieces of 1/4" plate to the cut ends of the original cross member that hung below the motor's oil pan drilled the plate for a couple 3/8" bolts, then welded a couple 1/4" plates to a piece of tubing with matching bolt holes to bolt up to the plates welded to the frame. Above the motor they made a single tubing shaped triangle part that bolted to the firewall and the top of the body structure, designed to clear critical motor components. That was needed to prevent the frame rails from rolling in at the top.
Use solid or poly motor mounts and the engine will help to act as a cross member. I know that sounds kind of Jenky but, I kinda remember V8 Vega's not having a cross member? Of course those aren't the best example of safety. I had a couple back in the day. One used a 2x4 with lag screws coming down through the floor as a cross member for the tranny.
Edit: They didn't have a cross member under the engine. Picture 3 looks like it was up in front of the engine?
https://www.yenko.net/forum/attachment.php?attachmentid=186846&stc=1&d=1613132527https://
www.yenko.net/forum/attachment.php?attachmentid=186852&stc=1&d=1613132585
https://www.yenko.net/forum/attachment.php?attachmentid=186845&stc=1&d=1613132527
Yeah it doesn't give me a warm, fuzzy feeling either. I've got a sheet of some high strength steel .100" that I had planned on stabbing the whole crossmember from side to side (with a ton of rosets) I might go two layers thick. I had also considered a 1/4 plate under the whole crossmember, if I can figure out how to bow it to match. Not 100% sure what the ground clearance under the thing is supposed to be. I didn't study it too hard. I knew I was gonna change it. I had no idea I was gonna have to try so hard to fit a LS.
I slept on it and decided stacking two pieces of 1.5 x 1.5 is better than a single 1.5 x 3. It let's me make these welds. On bigger tube, there is nothing to weld to.
