how to connect to plastic hardline?
Jimmy Wallbanger
Dec 3, 2010
323
Arkansas
my trany is from a 92 ford ranger and has that stupid plastic hard line with a quick disconnect directly at the tranny and a clip ring hold it to the master cylinder. I'm in the process of building my pedal set up and an the goofy angled bracket on the master cylinder just wont work. so im thinking of switching to a different master and have no clue how to attatch to these lines. Also my friend that owns the shop is having a similar issue. Could I use a 2 sided brass compression fitting with steel line in one end and the plastic in the other. similar to the ones used in plumbing? ill post pictures later of what the endslook like just wonder how you guys handle this.
I dont think you could ever get it to hold up to the amount of pressure without blowing apart.When I was doing my 46 I looked into flex and universal hoses,may can find something with the proper ends. May have a hydraulic shop make up a hose that would hold up to the pressure.I wound up using the stock one with a a little tweeking.
napa
actually napa has a fitting for connecting metal lines to plastic lines they come in a high pressure fuel kit i have a kit in the shop and have repaired many 60-80 psi fuel lines that go from metal to hard platic. they are available in 3/8's, 5/16's and 1/4 inch.
the difference being that one end has a sleeve that fits inside the plastic line to prevent crushing
i will post a pic and part number tonite
george
fitting
heres a pic of one and the part numbers for the diff sizes.
bk 730-5640 is 1/4 inch
bk 730-5641 is 5/16
bk 730-5642 is 3/8
you can bring them up on the napa web sit too.
george
Why not just get the 5/16" quick connect (I would imagine that's the size) fitting and make a new line rather than trying to work with what's there.
Looks like the same part I posted.
Advanced auto had the brass compression connector and that's where I got the idea. It still has the quick connect in fact I have the whole line a master but I Want to run a different master and the line is made for the factory one only. It's a quick connCt on the tranny with a barb if that gives anyone an idea but it1/8 tops
