RUSTY50F1
@$$Fault Junkie
Thanks; I still have to fab mine up. Mine has 331 gears. Do you still have to put supports behind the rear with the ones you put on the front?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Do you still have to put supports behind the rear with the ones you put on the front?![]()
And also if the rear cross member is welded to the frame and the irs is mounted stable to the cross member do I need to have a sway as well.![]()
