I got really tired of doing bodywork on my '40 Plymouth truck, which will be the tow car for this dragster. So I shifted gears and began assembling the new engine for the dragster.
I cleaned and recleaned the block, set the main bearing shells in place and dropped the crank in. It didn't turn well. I put the main caps on and torqued the bolts. It turned, but was very hard. The bearing clearance checks out at .0015" with Plastigage.
As you can see by the pic of the bearings the problem is in the dimension across the parting line of the block and main caps. See the shiny spots.
I filed a very small chamfer on the bearing edges, main cap edges and main journal edges in the block. Then I used Scotchbrite on the backs of the bearing shells and the main caps and main journals in the block.
After all this, the crank turns acceptably. But, I'm nervous. So I took the crank back to the shop to have it ground to the low limit of .0025" on both the mains and the rod journals. Hopefully that will keep this thing from spinning a bearing.
Any advice or opinions on this deal would be appreciated.
