Billy be stylin' now. [cl14.72 volts with everything turned on.
Starts easier and seems to run stronger
Pics would help. Are you talking about the mounting bolts? If so, maybe some higher grade bolts would solve the issue. If you haven't already done so, you might also want to check closely for any stress cracks in the area. Scab patches don't take up a lot of space.Loud noise from the steering yesterday
One of the bolts on the box let go.
Trying to figure out how to beef it up but there is VERY little room to work with.
The frame flexes as well
An incredible amount of stress right there
We mafe the plate bigger and put holes in it to match up with factory holes in the frame that weren't being used and then used 1/2 in grade 8sPics would help. Are you talking about the mounting bolts? If so, maybe some higher grade bolts would solve the issue. If you haven't already done so, you might also want to check closely for any stress cracks in the area. Scab patches don't take up a lot of space.
Those old military rigs are supposed to flex a lot. They were designed to go anywhere a soldier had to go.
Hope it's an easy fix.
