bob w
Bit by Bit
Made some minor revisions to the front floor/trans tunnel. I'm using the same brackets but making a new shifter mount out of 1/8" aluminum plate. The same panel will hold the switches, fuse panel and maybe the gauges. I want to keep all the wiring short and accessible with nothing mounted to the body.
I had to rotate the fuel cell mount 90 degrees because the fuel line will run up the driver's side instead of the other side. The existing braided line will reach now and I won't have to make up a new line. A little fab work saves some money.
