maddog
Here he comes to save the day!
Hey dog,
New direction looks good.
Jeff
Thanks, Hows your new ride? and your welding?
Hey dog,
Jeff
Maddog,
I like that new look you got going on the topo. Low and mean...
glad to see u back maddog, that car is going to be really different when it's done, which is a good thing. you could use those quick dicconect fastners that summit sells to attach the body. or you could hinge it at the rear with some hydraulics and delete the doors completly. just lift open the whole body and crawl out.
Welding is done, much simpler than I expected.
I’d be back on the street if I wouldn’t have gotten laid up with my bad back for the last 4 weeks.
Gotta install turn signals, wire them up, and then I’m pretty much there.
Still should have a good 3 months left this season.
I think it is a wise choice. Are you going to use a kit or build it yourself?
(Don't even get me started about bad backs)
Here is my favorite QE setup.
That makes sense to me. I now need to figure out how much spring to use. If I follow my usual pattern, I will blow through it just to get it on the road, then correct it later if its not quite right.
I am also considering a roll cage. What size tubing did you use? In my race car the cage stiffened the frame and that was good. How does a stiff frame work on the road?
These drawings are very cool. It is really neat to see and old style rod made from high tech design work.
Something I forgot to mention in the roll cage post. NHRA has requirements for tubing wall thickness for under 9 second cars. Just thought I would let you know just in case.
