StoneCold65
Too bad you didn't go AWD...I can see that beast doing some Rally racing against those WRX's with Ken Block behind the wheel or Travis Pastrana. ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Too bad you didn't go AWD...I can see that beast doing some Rally racing against those WRX's with Ken Block behind the wheel or Travis Pastrana.![]()
You have definitely put together something special here. Love the look, the stance, the hood, the suspension, the whole thing.
Is that an Oberg filter?
This is one that I can say I love ! Cool truck !
Simplicity, now you're just showin off!!
Well, this build has been moving very slowly here lately, but some progress has been made. Got the tranny back and it should be a pretty sweet one. Also got the engine pulled and took it to LME engines in houston where they are putting in the good stuff! It started life as the all aluminum 6.2L out of an escalde, and will be a stroked out to a 416 cubic inch cruiser when it comes back! Should lay down around 600 horses at the flywheel, and with the callies crank, callies rods, wiseco pistons, all arp bolts, and alot of other goodies should be very dependable. Also left room for a 250 shot of spray if it needs it...hehehe! Did a mock up of some motorcycle style fenders and they were looking pretty cool, so might have to build a set to run. But anyways, as soon as there is something cool to take pics of I will post em up!
Do you know the weight difference between the aluminum engine and the iron block engine?
That sounds like a whole lot of motor.
I hope you have it dyno'd. Really curious what it will produce. Do you know the weight difference between the aluminum engine and the iron block engine?
Di you have some diabolical scheme for using all that horsepower?
70 is the number I heard, and thanks for the good info!!!!Depends on who you talk to but it is between 70-90lbs
