Still catching up with the story. We're almost to present day.
Got a donor. Father passed away and I got his truck. 1999 F350 crew cab long bed dually 4wd. 7.3L turbo diesel automatic. 200k miles.
I really struggled for a while deciding if I should keep the truck as is and get it running well again or if I should use it as a donor and make use of the drivetrain.[S
The latter won out. The wife hates trucks and she didn't want it in the driveway anymore.
Stupid pics keep uploading as rotated...
Anyway, this truck is insanely large. I never really thought of it that big until I tried to fit it in my garage and started tearing it down.
I had to remove the bed and the rear section of the frame just to get the garage door to clear the front bumper.
I can't leave anything ugly in the driveway since my HOA will have a cow.
I felt really small next to this thing. The frame sat above waist level. It was stock height. Crazy.
This was the point that I started asking myself, "What the heck are you doing? You are in way over your head. You have never built a car. You are not a mechanic. The most you've ever done to a car is change an alternator, starter, or swap out a few sensors."
My stupidity won out. I kept going. I taped and labeled all the parts I took off. I threw out as much as I could. The garage was really full of parts from this beast.
Out came the dash after a couple hours of fighting with finding clips and bolts that were holding the thing in from weird angles and positions.
Took off the doors, carefully removing wire harnesses, etc. I'll need those window motors, channels, and door lock mechanisms later.
Oh my god. The A/C unit is HUGE on this thing. It's the size of a small Honda.
There are 2 halves: Inside the cab and inside the engine bay.
There is no way I'm going to fit it in the 33 Chevy to reuse it. Well, I'll figure that out later. Label all the pieces and put it in the pile of parts.
Oh, I kept the whole system sealed, which made this completely insanely difficult to remove. No hoses were removed, except the heater hoses. The A/C compressor had to be removed from the engine and the A/C radiator was bundled with the compressor, condenser and other sealed parts. What a PITA.
Dash is finally cleared out after a LOT of effort and stress. Am I going to be able to get this motor to start again later?
From several youtube channels on the 7.3, the consensus is that this motor is tough as a coffin nail and is difficult to kill. Good. It'll need it after me.
