serrata
I'm not happy at all with the travel of the front suspension.
I'm trying like crazy to be able to have a 4 link and keep 4 wheel drive, as well as be able to drop this thing to the ground.
I set the pinion angle at the lowest point, but figured I had enough adjustment in the links to adapt to driving height.
Uh... Not so much. When I raised the suspension, the angle changed like 30 degrees. Holy cow.
Sooo... I shortened the longer arms and moved the frame mounting point forward 10.5 inches.
Here's what it looks like now...
I have another major problem.
The front end is so heavy with the engine up there, the air bags won't lift the front more than like 4 inches. I had placed the bag near the center of the beam, which pretty much doubles the weight they carry, but would notionally double the lift height. It didn't work out that way.
When I shortened the lower arms, it made the weight problem worse. Now it only comes about 2 inches off the ground and movement is very soft and mushy.
Also, pinion angle change on lift is still pretty severe. I'm realizing that having the height of the frame-mounting points for the 4 links all at about the height is exacerbating the problem. The rear isn't suffering from this problem mainly because the diff in height at the frame side mounting points is about the same as the height diff at the axle side.
So....
I'm thinking I need to move the bag closer to the axle to resolve the weight problem.
And I need to somehow raise the frame-side mounting points for the inner triangulated upper arms without getting in the way of the future front driveshaft. And possibly make the 4 bars closer to the same travel length.
Ugh.
So....
Ugh.
