Great to hear bob.[cl [cl [cl
It is a really non invasive procedure these days.![]()
Last night I trekked over to a young friend's house to see what I could find. He has more early Ford stuff than Carter has Little Liver Pills. Came up with a parallel leaf spring kit which I'll use for this build.
The front axle is from my Crosley. It is a dropped, narrowed Magnum axle with Wilwood brakes and a Geo rack and pinion. After I remove the batwings the spring brackets will be moved outboard a bit. It was mounted with coil overs and a 4 bar on the Crosley so all that has to go.
Here's the way the Renault sits with no engine/trans. Should I go higher in front? Lower? or is it okay the way it sits?
