Old Iron
[P[P[P
Hadn’t thought about it really, I’ve never seen a set that actually looked like they might contribute anything more than marginal stiffness to the body. If I would make a set, they’d have a flange on both sides for the full length and be spot welded every inch and a half or so
Dr.C is right, the 6 cyl cars are thinner metal and flex, even with the 6!
I’d go ahead and build a frame to fit the body. That way, you could make the front end a full tilt for access, and in the rear, have a good, solid place to mount the suspension and rear end. You could narrow the rails in back so you could get a huge tire inside the fenders if you wanted. A 2” x 3” would be plenty big, and strong. You could even channel the floor halfway over the frame and it wouldn’t be noticeable from the side.
Hey Doc, I see you visited Elpolacko’s page, is that Norm Grabowski ?
El Polacko has a hot rod fabrication business in Arizona, I think. He used to be on the HAMB.
I think he was on here a while, too.
I was just wondering because I read in an old hot rod magazine about him joining one of their power tours and he was going by Elpolako. I’m gonna see if I can find that issue.He was on both sites. He's a smart cookie and I've learned a lot from his MII writings...
http://www.industrialchassisinc.com/
I'm still confused, Bruce. When and where did Norm Grabowski fly in?
Unless they have WiFi where he’s at.
