stilltryin
- Joined
- Nov 28, 2016
- Messages
- 9
I am not a welder fabricator and my questions might seem idiotic to some of you more experienced guys. I have a few questions regarding using an actual mustang ii front suspension on a 32 chevy. The project I picked up has one partially installed however while the rear of the crossmember hits the frame rail and is welded in place the front does not touch the frame due to the narrowing of the frame as it goes forward towards the frame horns. There is a noticeable gap between the front of the crossmember and the frame. I know I am not the first person to come across this so is a plate or piece of angle typically used to tie the 2 together? I also am building a full fender car and the upper control arms will not fit so I guess I need to use a tubular aftermarket set of arms, will these bolt up directly like the factory ones? There is also a stabilizing arm thats part of the original setup in place hanging below the car but there is no way this will work in its present location. I have search the internet for picturs but all I ever find are aftermarket ifs setups. Any and all help is appreciated.
