zzrodder
Looks good, every problem has a solution - if it was easy, it would be boring.
I may end up with a similar engine mount, that's coming up soon....[S
I think my shock mount is in the way. I will look at that tomorrow. How much of a problem do you think is is if I can't?
Yes your right, the floor framing will be tied in to that notch and the sills... perfect.
Did you see my question on wether I need additional reinforcement on my frame in the center section on your last build post?
Thanks ZZ
View attachment 169779![]()
My opinion on adding more to the center of the frame is yes, but then I also tend to overbuild.... The way I see it is that there is a long stretch between the front crossmember and the rear kickup with nothing to prevent twisting other than the framerails. Of course there are several considerations like the position of the booster, which makes it tough to make reinforcing members symmetrical like with my frame. Also you may need room for exhaust? Or not? In my case, I'll have enough ground clearance that it can run below the frame without hanging too low. Here's a pic of another frame I built for my Black Rat 55 - the exhaust ran out side of the frame on this one.
ZZ.... do you see that black air bagged frame above? That's the frame I was referring to on the powder coat question.
