soltz
The Rat Captain
Yep [cl[cl
I'm just an observer here but, with that Hemi mounted that high, the truck will have a lot of corner roll.
Setting the bottom of the pan level with the bottom of the frame rail would eliminate some of that.
If you're going to run a mechanical fan that would be more in the center of the radiator too.
Looks very cool!!!!!!!!!
There's nothing like a Hemi to make a build awesome![cl[cl But like OI said, that's kinda high to mount it, plus the higher it is, the bigger the trans tunnel will be, and you need all the space you can get in an already chopped cab. Just my 2 cents worth.......
That's a whole lot of engine for a pretty small truck
Might as well put a blower on it too!!!!
I have enough trouble getting my '47 Dodge to stay hooked up and I've only got a Dodge 408 Stroker in mine..
Looks like a ton of fun.
Enjoying following along.
