26Troadster
- Joined
- May 22, 2007
- Messages
- 4,096
cool build, like the hemi.
Cool build, nice having 3 generations together. [P[P
Coming Along [cl
**[P**
Looking good! Love those rear meats.
As long as the bottom of the pan is 2" above the bottom of the lowest frame rail, it's good.
Or 2" above the bottom of the front axle, whichever you want.
With the engine at a 3 degree down in the back, this puts the tranny pan around an 1" above the bottom of the frame rail/front axle.
Either one as long as the oil filter clears the top of the frame rail.
The lower you mount the engine/tranny the smaller the tranny tunnel also the further forward you place the engine the more foot room you get.
If you're going to run a mechanical fan the center of the water pump need to be close to the center of the radiator. If you're going to run an electric fan, then this doesn't enter into the equation.
Couper, you've got a the best advisor in Old Iron. Keep up the good work.
Coming along Couper and looking good [cl
I'm also one of buy old and repurpose to my needs [
Keep at it!![P!!
